As far as where you stand, or are "starting at" you already have that answer. What you need to remember is that you have a set that is around 50 years old. Capacitors were never meant to do their job that long and operating your set with them is operating a ticking time bomb. ESPECIALLY if a set has been dormant for many years which is normally the case. No, the set wont explode but a shorted capacitor can and will take out much harder to find and much more expensive parts like the power transformer (if equipped), or the flyback transformer. The topic of recap or not recap is always in debate here and I think it is good that it comes up from time to time. I myself have sat in your shoes many times until I finally fried the power transformer in a 1949 RCA. In a nutshell you really should replace at the very least all of the electrolytics and paper capacitors. Personally I believe that the paper caps cause more trouble than anything. Many times old electrolytics are still holding their own; but for how long? You can leave the ceramic disc caps alone pretty much as they don't seem to cause a lot of trouble. Remember if you replace any caps that the capacity rating should be as much as the original or somewhat higher if needed. The working voltage MUST be the same or ANY amount higher. Also electrolytic capacitors ARE POLARIZED. Pay CLOSE attention! You can get "orange drop" replacements for all of your paper caps and you need not worry about polarity with them. They are cheap and last a LONG time. I have three sets from the 50's that are functional with most, if not all original components, but I would not want to operate them for hours at a time. Especially not without sticking close by! Like I said domancy is a factor and the sets I own have been in my possession for at least twenty years and were being used at least periodically before I bought them. In other words they have never sat for decades without being used and I believe that is the only reason they still perform. For the most part my use of them has been limited. That also helps... With a recap you will be able to enjoy the set, and better yet not drive yourself crazy having to constantly decipher some new problem. You also need to check and replace any resistors that are out of tollerance, and I'm sure there are a few. They are not as touchy as caps as far as age. If they check OK leave em.... I hope this is some help and good luck...
"Face piles of trials with smiles, for it riles them to believe that you perceive the web they weave, and keep on thinking free" |
