Originally Posted by zenithfan1
I picked up one of the Insignia boxes over the weekend. {Still haven't got my damn coupons yet}I get a slight buzz but nothing major, only when a really bright white screen is present.
That's what happens if the video level is a little too high. White parts of the picture is when the RF amplitude is at minimum. And the modulator could be going to zero RF amplitude if the input video level is too hot. The buzz happens to the sound because the TV set intercarrier system stops working when the picture carrier is forced to zero by the whites that are too hot. As the 4.5Mhz sound IF disappears momentairly, and the FM detector produces a spike at each white spot. As the scan rate of the picture is about 60Hz vertical, those white spot dropouts repeat at 60Hz, making that buzz sound.
After the warrenty period is up, crack open the box and see if you can find the video line feeding the modulator, and add some resistance in series, or to ground, to reduce the amplitude a little. But you'd have to be sure that doing that doesn't mess up any DC biasing.
A set from the early post war days that uses completely separate sound and video IF strips won't have this problem. But otherwise such a set is hard to tune a TV channel on.
