Old 03-22-2008, 08:51 AM
RetroHacker RetroHacker is offline
Electronics Accumulator
6BK4 jingle
Thought I would make this it's own thread, and do a quick poll about this. I noticed in my Penncrest CTC-15 clone, when I pulled the 6BK4 out, it jingled. The used tube that came with the set also jingled when it was tilted. What causes this? I know tubes like the 83 have mercury inside, and those can jingle or appear to have metal inside them, but a 6BK4? In both cases, I was unable to see anything loose inside the tube. And both tubes worked (although one failed after about five hours of use)
Another AK'er commented that he noticed jingle in his tube. Is this something common to all 6BK4's? A common failure? Coincidence?
Inquiring minds want to know.
-Ian
Old 03-22-2008, 11:36 AM
kx250rider's Avatar
REAL TVs have TUBES!
That's weird. I don't remember seeing any 6BK4s with loose parts inside; at least no more than any other tubes. I'd replace it. They're a dime a dozen. I don't think there's any way that the TV could have caused this. Probably just two tubes that were both dropped at one time.
Charles
Old 03-23-2008, 08:30 PM
Lumpy vacuum?
Old 03-23-2008, 08:45 PM
Dave A's Avatar
Dave A Dave A is offline
Loose chips of glue in the base bouncing off the bottom of the glass?
Dave A
Old 03-23-2008, 09:11 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
I have a feeling that the 6bk4 will be a tube we'll never have to worry about running out of.
This device isn't a spaceship, it's a time machine. It goes backwards, and forwards... it takes us to a place where we ache to go again.
Old 03-24-2008, 12:43 PM
That's a pretty simple tube-not too much can go wrong. I haven't seen a pattern of rattles in them, but various tubes I've had over the years have done it. Sometimes a little piece of glass rattling around, or a chunk of glue in the base like Dave mentioned. Some tubes have insulators/seperators that will just naturally rattle.
