Old 03-17-2008, 07:45 PM
I got very lucky. The good news came back from Moyer and they actually have a thordarson Y-137.
Its interesting to note as to how this yoke failed. You are all probably familiar with the goop that accumulates around the HV anode cup on the CRT on Zeniths that use the translucent yellow HV cup. It breaks down and becomes sticky residue and it leaks down the CRT. This set got so bad that the oil went down the neck of the CRT and onto the windings. It broke down the resin coating on the copper and corroaded. This eventually caused HV to arc and then carbon built up and snowballed into a nice large burn though of this particular section of the windings.
I got this set from carmine and talked to him about the problem. We discussed what the problem was that could have caused it and he suggested this possibility. Upon inspection, that was definitly it. The yoke apparently was up against the CRT which lead to this oil getting on the windings causing the failure. So watch out for those oily looking CRT's and check the yokes!
I didnt know yokes were this common on Zeniths of this type. Anything in particular as to why else they were known for failure?
