Interesting that your set has the emblem which lights up when the Space Command system is on. (The volume indicator lights are unusual as well; yours is the first Zenith SC set I've ever heard of with this feature and also with the illuminated Space Command on/off indicator.) As to your set failing to stop on channel 4, I would look at the back of the tuner. There should be a wheel there, attached to the part of the tuner shaft that protrudes from the back of the tuner, with 12 adjustable tabs on it. Check to see if the one for channel 4 is set to the "skip channel" position. If so, set this tab to the "stop on channel" position. The tuner should now stop on channel 4 just as nice as you please. BTW, I remember seeing your local channel 4 in my old neighborhood (a Cleveland suburb) years ago, before I had cable or Internet access. I live in a fringe area now where anything is possible as far as TV or FM DX is concerned (my FM radio dial lights up with stations from Detroit, Toledo, Ohio and southwest Ontario, Canada, in the summer when the skips are in), but my old neighborhood was a near-fringe reception area for Cleveland stations as well. When the weather conditions were exactly right, channel 4 from Port Arthur, Texas would push Detroit's NBC affiliate, WDIV (which is the station we usually get here on channel 4 in the spring and summer when the band opens up) right out of the picture (pun intended). I once received channel 5 from Saginaw, Michigan when Cleveland's ABC affiliate, WEWS, also on channel 5, was off the air. The station in Saginaw is WNEM-TV and is, IIRC, a Fox or UPN affiliate now, but it used to be the area's NBC station. When WNEM changed from NBC to UPN/Fox, the NBC network was picked up by WEYI, channel 25, in Flint or Bay City, Michigan (I'm not sure which). I have seen the latter station on occasion as well in the summer (when I still had an antenna, of course), when the PBS affiliate in Cleveland, WVIZ on channel 25, would sign off at one or two o'clock in the morning.
