Old 02-10-2008, 10:07 AM
Mike Stamper Mike Stamper is offline
AK Member
Using your suggestion (re: Ohm's Law to measure the 6BG6 cathode current). I measured the resistance to ground (149 ohms) and the DC voltage to ground (12.92v). I found an ohms law calculator, which yielded the result of 0.08658 amps, or 85 milliamps.
Old 02-10-2008, 11:11 AM
Old1625's Avatar
Old1625 Old1625 is offline
I've felt right along that the HOT is being overdriven for whatever reason. And your voltage readings and calculated cathode current seem to jibe with this. As well as your clipped sawtooth waveforms, which indicate the control grid being driven well into conduction, which would result in an increase of developed negative bias. IIRC a normal cathode current would be more on the order of 100-110mA....
Assuming the replacement flyback has the same numbering as original as shown in the schematic the width coil goes to pin 3 and returns to the B+ line, while pin 4 of the flyback is connected to boosted B+ through a fuse.
The reactive effect of the width coil loads the circuit so as to change the current through the deflection coils to control width. That removal of the width coil should so profoundly change the generation of HV in a separate winding makes me wonder if the coil has an internal short, or that perhaps there is some confusion in the numbered callout of terminals on the flyback itself.
Old 02-10-2008, 03:35 PM
AK Member
OK. I give up. It was the fly-53. There was nothing wrong anywhere else. I rescued the OEM flyback from the parts bin, repaired it, and reinstalled it. I got 10k immediately, and more when I advanced the horizontal drive. One of the wires (to pin 4) on the original flyback broke. I had lost all hope of fixing it. Today, I thought I would give it one more try. Using an x-acto knife, I scrapped the insulation from the remaining wire. I then found a small piece of stranded wire, wound it around the remains of wire #4, got my tiniest solder tip, and flowed a little solder onto the connection. I verified that it conducted, then soldered the stranded wire to the post. I pulled the fly53 and reinstalled the original. I turned the set on and it worked perfectly. A little tweaking of the width and drive controls (which now work correctly) and the picture was full and bright. I am now done with this set, at least until it breaks again. Either:
1) The fly53 doesn't work very well in this set
2) The fly53 I bought was damaged
3) The instructions on connecting it were faulty
I'll post a picture soon. Thanks for your help.
Old 02-10-2008, 04:05 PM
Old1625's Avatar
Glad to hear you got it going! Good show!
Of the 3 probable causes you listed regarding FLY-53 it could've been any one of them.
A pic of this triumph will certainly be well received and enjoyed here.
