Old 02-09-2008, 12:43 PM
If it has a pot for vertical size, it would be as simple as adding a second pot and a switch to change which one is in circuit. You should try to design it so that it doesn't lose vertical deflection when when you switch it. For examplt, if lower resistance = a larger picture, then set it up so that the second pot is connected in parallel to expand the picture for full screen.
Be aware that there may be objectionable stuff visible in the VBI when the picture is compressed. Macrovision and other VBI data will probably show up. TVs with a 16:9 feature have to blank this.
Old 02-09-2008, 04:41 PM
johnfull johnfull is offline
AK Member
Thanks, Andy.
It does, indeed, still use the pots for some
functions. The Bias and Drives and Pin Cushion
and Horizontal Centering and Vert and Horiz
size are still like the good old days.
I think I might experiment with cranking the
pot that's there first to see how it looks before
going further. I'm not really a technician, but I
know some basics. The idea of having additive
resistance is a good one. I hadn't thought of
what would happen in that split second when
there is no signal at all between the two values.
I guess it could fry something to concentrate the
beam at full bore on a single raster line.
The problem I have with the pots is that they
seem frail. After so many years, the Bias and
Drive controls have gotten non-linear. It takes a
lot of patience and even more luck to get an
acceptable setting for those. I would hate to think
that the vertical size is just as frail, but I bet it is.
Thanks again!
