Old 02-05-2008, 10:54 AM
kx250rider's Avatar
REAL TVs have TUBES!
There was a kit for that power supply, which includes the caps that Radiotvnut mentioned, and also the IC and several transistors, diodes, and resistors. One of the caps is a weird non-polarized electrolytic. Being out of the business for over 5 years, I can't say if they still have that kit. It was an aftermarket kit, which was available at places like Mat Electronics, and Fox International. Maybe someone else will know who has it. If you want the kit and can't find it, I have one left over "for a rainy day". I would prefer to keep it since I have several friends with those 169s, but I would be happy to itemize the kit for you.
The bad possibility is that the HVR block is shot. That's nearly as common as the VIPUR (power supply in those RCAs) being blown. Those aren't available anymore from RCA, but I heard that there are aftermarket ones that work fine.
Also, if you haven't noticed, it's EASY to remove the whole chassis box on those sets so you don't have to lie on your stomach to work on the set, as you do with most other big screens of that age. There are 2 long wood screws on the sides of the particle board chassis housing that hold it to the cabinet. You remove the speaker grille, unplug the control panel, and slip the whole chassis out, tubes and all
Charles
