Old 01-13-2008, 07:15 PM
Sounds like a flash back to the '90's and the bad Zenith CRT's. Even if you have a good CRT tester; the tube may not check shorted if it's intermittent unless you can tap on the neck and make the tube short while it's on the tester. You might try laying the set face down and tap on the CRT neck with the set on. Sometimes, this will knock whatever particle that is shorting the gun down in the tube. The tubes in the Zenith sets would short and take the power supply with it. I got to the point that if I saw a burned up power supply in a '90's Zenith, I junked the TV. BTW, I like the B&K 467, 470, 480, & 490 model checkers. They will check most CRT's (with the proper adapter) and the rejuvenate function will not burn up the tube, unlike earlier models. The Sencore CR70 is another later model that should do well. Even though these checkers cost several hundred to over a thousand dollars new, they can often be found used for less than $100. I suspect they will get even cheaper as CRT based TV's become less popular.
