I believe the blue and red wires define a single coil as do the yellow and black so I would expect the R to be 0 for each of these measurements, which it is. Please tell me what you had in mind here.
I get about 140 volts red wire to ground. *FLASH* HV back, everything perfect! The Horizontal Board felt a little sloppy when I wiggled it. Got out a pin and bent in the spring tabs on each board socket. Voila! So it turns out the whole problem was the 50MFD cap/1.5 OHM res problem which originally caused right-side foldover and finally popped the horiz output transistor. I have used the pin fix method on these modules many times before. Most of the modules eventually got soldered, but in anticipation that the high voltage section would eventually need attention, I didn't do the horiz or vert output ones. My sincere thanks to all who have helped here, especially KX250rider and radiotvnut. Frank |
