Old 12-15-2007, 09:46 PM
peverett peverett is offline
I still contend, that if HDTV is as good as analog, I would not need any special antenna where none is needed for analog. I agree with your theory as to what is happening. This just points out a major weakness with whole digital broadcast system. When the signal(or signal alignment) is lost and then recovered, the receiver has to re-align its PLL with the incoming signal, then re-align the received frames, and then begin decoding the signal. All this takes time that the analog system does not need to spend.
The plus side of the digital system is that you can do error correction on the digital signal for some defects. Also, you will never see ghosts, snow, and such using a digital signal. The main issue for me is the reliablity of the system. Is it reliable enough that the loss of signal issues mentioned above are rare and I can enjoy the plus side. So far in my experience it is not.
Some would point to the quality of the HDTV picture over the analog one. However, this is very dependent on what is broadcast. The last time I checked, only two of the six local channels were broadcasting 1080i. One , Fox, was only broadcasting 480p.
One final item that I would point out is that the rabbit ears that I am using are amplified and of recent manufacture. The are advertised as "Designed for HDTV reception" for whatever it is worth. They are not antique as some of my TVs are. The UHF loop that I am using for the analog signal is not amplified and is probably as old as the TV it is on(1967).
