Old 12-08-2007, 08:46 PM
I think the last tube color set I saw in daily use was in the mid '90's at a friend's antique shop. It was a '76 GE Portacolor and it saw daily use as his shop TV. It went belly up in the mid '90's and I gave him a solid state 19" Zenith to replace it. I should have kept the Portacolor since it was one of the last tube sets made. I used to get a lot of tube sets in the '90's from older people. These sets had either been sitting unused for years or had just broken and the owner did not want to spend any money on it because of it's age. I suspect there may still be a few tube sets in use; but, they are probably in secondary locations and will most likely not be repaired once they die. Most shops would not touch a tube TV and tubes would probably be hard to find locally even if the owner knew how to change tubes. Most shops around here stopped taking in tube sets in the mid '80's. Most of what's left in the way of shops around here are too young to know what a tube is.
