Dont know this set at all, never worked on one. Id agree that the drilling caused the short. metal shavings fall on a filter cap that is upside down? (cap terminal lugs up when the set is in its normal position) Shavings could be shorting anything out in the vicinity of the drilled out area. Did the drill bit push something to ground when it "jerked" through and you didnt notice it happen?
Just a thought...could the chassis be a hot chassis? The outer case of the "f" fitting could be in contact with a hot chassis...connect the cable....short to ground. Wouldn't be the first I'd seen. It was common for folks in the early 80's to replace the screw terminals with "F" fittings to make sets cable/Atari/MATV ready. I remember one set a customer had tried to modify for an F fitting - an RCA we never could fix - burnt runs and vaporized rectifiers in the B+.....
Just a thought, not at all familiar with the 8-301W.. Cheers,
