Old 11-15-2007, 04:15 PM
Those brightners were real common from the '70's on back. They plug in between the set's CRT socket and the tube. What they do is boost the 6.3 volt filament supply to around 8 volts. This action causes the cathode to get hotter; thus, increasing emission. These brightners won't work with newer tubes. I've seen some sets with flyback powered filaments that actually had a warning inside the set claiming that the use of a brightner could draw too much current and burn out the flyback. There are, however, some newer solder in brightners that are designed to work with newer sets. I think they're about $15.
