Re: What is going on here?
There's no accounting for what some people will do with a TV set (or anything else) they find in a trash pile. I mentioned in another thread a few days ago how kids often destroy CRTs in discarded sets by throwing rocks at the screen or knocking the neck off, even though the tube itself might have been perfectly good. The same sort of thing could be happening with these TVs that are missing the yokes. Someone, as you just mentioned, may have figured they could get something for the wire in the windings although, as you also said, it wouldn't be much. I once found a 23" Zenith console in a neighbor's trash in my hometown that was missing all its tubes, except the CRT and HV rectifier. I've wondered since then whether the original owner kept the tubes for another set or a junk box, etc. or if some electronics bug in the neighborhood took the tubes for use in another application. BTW, jasonlava mentioned in another post having had a 20" RCA square-corner TV in the late '80s that produced an excellent picture, "better than any other CRT television" he had seen to date. That was characteristic of all RCAs before Thomson took over the company in the early '90s. However, I have a 1999 RCA CTC185A7 with a dark-tint tube that makes a very good picture on cable, much better than many of the earlier sets I've seen with delta-gun tubes, shadow masks, and gray or green faceplates. Someone mentioned in a thread here some time ago that the quality of RCA color CRTs actually improved when Thomson bought out RCA; if so, I believe it. My set was purchased new over four years ago and still has the original CRT, no problems with it (the CRT) whatsoever (shorts, etc.) in all that time. In fact, someone else said in a post to another thread awhile ago that the failure mode of most RCA CRTs is shorts; if the tube goes for several years without shorting, it will last quite a while. If that doesn't speak volumes for how RCA's CRTs have improved since the late 1980s, I don't know what does. Now, if they would only resolve those pesky on-board tuner issues . . .
Jeff, WB8NHV Collecting, restoring and enjoying vintage Zenith radios since 2002 Zenith. Gone, but not forgotten. Last edited by Jeffhs; 04-16-2004 at 01:39 PM. |
