Old 11-06-2007, 04:31 AM
dr.ido's Avatar
dr.ido dr.ido is offline
Here's a couple of HD boxes that were mixed in with the last big stack of DVD players I picked up.
This is an NEC NHD-2000. It's actually made by Macro Images Technology, but I can't find any information on it either under their model number or the NEC model number. It looks to be a decent box with composite, S-video, component, RGB and HDMI outputs. It has access to the menus via the front panel controls (important here where most of these arrive without their remotes). Strangely the board appears to have a PCI connector, but I don't know what it's for. Unfortunately the SMPS IC blew it's top and I can't indentify what IC it is, so I doubt I'll ever get it doing unless I find another one of the same model.
This is a DGTEC DH-2000A plus. This one is older. It was one of the first cheap HD boxes around here (at AU$599). It has composite, S-video, component and RGB outputs, but no DVI or HDMI. It looks like there is a similar model that has a built in DVD player, but I haven't seen one. It was probably dumped because someone set it to output something their TV couldn't display and couldn't work out how to change it back (this happens a LOT around here for some reason). There is no access to the menus without the remote, but you can change the video mode by holding down the channel buttons on power up. Of the 3 available video modes that it will output via the RGB connector 2 work on the AOC 17" VGA monitor (576p, 1080i?) on the test bench. The other (720p?) it won't sync to and displays an error that it can't sync to 28.1kHz (which doesn't make sense for 720p. I haven't tried it on any other monitors yet.
The picture from channel 9 HD in 1080i (I think). The monitors adjustments are at 100% H-size, but the image still isn't quite full width.
