Old 11-02-2007, 01:20 AM
The HV transformer is allright , if it was working . If it produces a horizontal line across the screen , and any brightness at all . it is all right . If I was going to put my finger on the wax , I would say there was a leaky cap in the HV circuit . Be sure to replace the caps around the flyback transformer , and also in the output stage of the horiziontal these are usually 1 KV and up . I have never serviced these sets before , wa2ise's J hook advice would work great on it . just clip the lead right at the cap , and take needle nose pliers , make a J and then do the same on the new cap . the other way is , make a little loop , on the new cap , snip the old one, leaving about a 1/4 " of it above the circuit board , the fit the new one , with the loop onto it . then solder it into place . It works , but the " J HOOK " is the best I find also .
Fuji , your signature make a lot of sense .
