Old 10-28-2007, 12:31 AM
MRX37 MRX37 is offline
All right, here's another update:
Removed the tuner IF can from the main board yet again. Checked all the coils for bad solder connections and could find none. Put the tuner IF can back onto the mainboard and soldered it into place.
I messed with the AFT coil until I got stable audio. then I got curious and tried one of the other coils and BINGO! Got a picture! That's not the end of it though...
After hooking the TV to cable and testing every channel, I turned the TV off and unplugged it. I left it that way until it had cooled off, then plugged it back in and turned it on. The picture was messed up again. I let it sit there and warm up, but the picture didn't come back, so I started adjusting the coils again.
I got it to a state where it would have a clear picture, then wavy lines appeared and grew more prominent until the picture went out. The picture would come back a split second after going out and be nice and clear, then the wavy lines came back and grew more prominent again until the picture went out again. It did this over and over, on every chennel I tried.
So I turned it off and unplugged it again, and left it sit for 10 minutes or so, then plugged it in and tried it again. Again, no picture.
I am starting to seriously suspect that there is something else wrong, and whatever it is, it's affecting the tuner.
