So 40 years x 7= 280 years!, that should be sufficent.
Your set uses a #219 bulb. RCA p/n 117435. Its a 6.3v 250 mA bayonet base with a spherical envelope. Very important to use the correct bulb, especially in an RCA. The #47 will be too close to the dial drum and will create a burn mark on the channel strip.
You should replace the other bulb too. Im surprised it worked when you swapped it out. Every time I pull a tuner with its original working dial lamps and then reinstall, 9 times out of 10 the VHF bulb won't light! Here's a place online who has them in stock: http://www.electra-ica.com/special/microlamp/
I tolerate the present by living in the past... To see drh4683's photo page, click here To see drh4683's youtube page, click here Last edited by drh4683; 10-26-2007 at 05:59 PM. |
