Guessing it's a #47 lamp?
If it calls for a 47 then use a 755, 7x the lifespan. Dave.
11-Altec A7(515/802/511B/N501),Model 19(416/802/811B/N1201),Model 18(604-8H),604-8G,8K,604C,604E,Model 9,EV Interface D,LT12,Koss CM1030. Soundcraftsmen MA5002,MA5002A,Pro-Power3. Toshiba SD5700(8),SD4700(4),SD3750(9). RCA 10 band EQ w/expander(3). HK Citation 25(2),Mac C27,1700. Marantz 2270(3),4300,2285B,2325,2226,2230,2240,2245,2250. Lafayette LR1500TA(2),Allied 395(3),Pioneer SX1010,850. |
So 40 years x 7= 280 years!, that should be sufficent.
Your set uses a #219 bulb. RCA p/n 117435. Its a 6.3v 250 mA bayonet base with a spherical envelope. Very important to use the correct bulb, especially in an RCA. The #47 will be too close to the dial drum and will create a burn mark on the channel strip.
You should replace the other bulb too. Im surprised it worked when you swapped it out. Every time I pull a tuner with its original working dial lamps and then reinstall, 9 times out of 10 the VHF bulb won't light! Here's a place online who has them in stock: http://www.electra-ica.com/special/microlamp/
I tolerate the present by living in the past... To see drh4683's photo page, click here To see drh4683's youtube page, click here Last edited by drh4683; 10-26-2007 at 05:59 PM. |
