Old 10-24-2007, 10:09 AM
It's probably 6.3v, but you should check. As radiotvnut said, there should be a number on it. These are standard lamp types that are still available today.
Old 10-25-2007, 04:06 PM
Findm-Keepm's Avatar
Followin' the Rules...
It's not one of the bi-pin lamps, it it? RCA used some of these - if it is a bi-pin lamp, I've got some. There are two types - both have a black metal cylinder around the bulb - one type has the cylinder open at the end, the other with a closed end and a rectangular window in the side.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 10-25-2007, 07:09 PM
dgwojo's Avatar
dgwojo dgwojo is offline
Away 8/14 -->8/16/2009
Get the number off the original lamp and we'll see if we can help you, I have many bayonet base lamps if that's what it takes, Dave.
11-Altec A7(515/802/511B/N501),Model 19(416/802/811B/N1201),Model 18(604-8H),604-8G,8K,604C,604E,Model 9,EV Interface D,LT12,Koss CM1030.
Soundcraftsmen MA5002,MA5002A,Pro-Power3.
Toshiba SD5700(8),SD4700(4),SD3750(9).
RCA 10 band EQ w/expander(3).
HK Citation 25(2),Mac C27,1700.
Marantz 2270(3),4300,2285B,2325,2226,2230,2240,2245,2250.
Lafayette LR1500TA(2),Allied 395(3),Pioneer SX1010,850.
