Originally Posted by andy
So, it's not composite like LD. I wonder if an S-video output could be added?
It is a strange kind of composite video, where the chroma subcarrier is at around 1.5MHz instead of 3.58 MHz. They did that partly because they didn't have enough bandwidth to have it at the usual 3.58MHz. This also allowed them to remove the effects of wow and flutter (from the turntable spinning at 60/8 times a second) by varying the beat frequency used to shift the chroma subcarrier from the 1.5MHz to 3.58Mhz. The resulting 3.58Mhz would be compared to a local reference crystal and the error would then shift the beat frequency up or down to correct it. A little like a PLL (phased lock loop). The beat frequency was about 5.11MHz, beat that against the 1.5MHz and you get 3.58MHz.
In a sense, there's no overlap in the luma and 3.58MHz chroma, as the luma bandwidth cut off around 3MHz, and the chroma bandwidth was about 600KHz. You can still sometimes see cross luma into the 1.5MHz chroma, though. Nothing you can do about that, as it's that way on the disc.
