Old 10-20-2007, 09:16 PM
Post
Originally Posted by Celt View Post
RCA should have made the CED players better. Mine was prone to act goofy and skip. The cheap plastic lightweight platter didn't help things in that regard.
The reason for the skips and goofy action was impurities and dirt in and on the disc itself. They had a firmware mechanism for getting out of "locked grooves" but nothing to force it back to get the video skipped over if a piece of dirt kicked the needle forwards. I knew one of the guys developing this stuff, and he said that it wouldn't have been a big deal to write the code to do that, but some bozos in management wanted to freeze the design as is and ship it...
Old 10-21-2007, 08:38 AM
Whirled One's Avatar
Whirled One Whirled One is offline
I wasn't aware that a software 'fix' was even considered or possible for that, but yeah, if you get an old well-used CED disc (like one that was originally a rental), they tend to skip all over the place-- especially the first time you play the disc after it has been sitting for a while.
Anyway, if your CED player skips badly and acts goofy the first time you play a particular disc-- but improves dramatically if you go back and start playing it again-- then the problem is dirt and dust stuck to the disc (a.k.a. the CED "video virus"). On the other hand, if your CED player skips a lot on all discs no matter what, then the problem is more likely that the stylus is worn.
