Old 09-17-2007, 05:10 PM
freakaftr8's Avatar
Convergence freak!
Need Help with 1978 Zenith Chomacolor II
Hey there,
Well I cannot seem to figure this one out. 17" Chromacolor 2 with rotary tuners, circa late 1978.
The left side of the picture is dimmer than the right, I may be dumb and should know what this is, but any ideas? Picture focus, color and contrast and black level all operate as they should..
This is a module style chassis...
Old 09-17-2007, 05:15 PM
I don't know where it is physically located in this particular chassis; but, look for a 10 uf, 350 volt (or a value close to it) electrolytic cap. This is the value that was used in the later sets and was a common failure. Your cap will probably be located on the flat part of the chassis where all the power supply components are.
Old 09-17-2007, 06:39 PM
If you'll post the chassis number; I'll see if I have a Sams Photofact and I'll tell you where the cap is physically located and it's exact value. This cap is in the 200 volt supply to the video output circuit. I've seen that cap defective in the later System 3 chassis and cause the same problem you are having.
Old 09-17-2007, 07:04 PM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
Agreed. I had the same thing on a SYS3 set. Capt'n Moody fixed it.
Very weird problem.
From Captain Video, 1/4/2007
Old 09-18-2007, 01:34 AM
freakaftr8's Avatar
Convergence freak!
You guys are awesome, ill get into it later this week and let you know, ill look for that cap too! Thanks!
Old 09-18-2007, 01:29 PM
kx250rider's Avatar
REAL TVs have TUBES!
If yours has a board on the CRT socket, the cap may be on there. If not, it may be on the 9-88 module. On the later sets (Sys III,) it was on the main board near the FBT.
Charles
Old 09-19-2007, 01:44 AM
freakaftr8's Avatar
Convergence freak!
Found it, it's on the chassis bottom oppisite of the FBT. Ill change it out in the next few days and let you guys know how it does! Oh yeah the chassis no is 17KC55 and tv model no K1720W
Old 09-19-2007, 02:28 PM
kx250rider's Avatar
If I can find that manual, I'll take a look. The K line is about the very last Chro II chassis. They had some weird things added, and some special modules for the smaller 17" cabinets. That could affect where that cap is located. I didn't think it was on the bottom chassis piece though.
Charles
