[QUOTE=Tubejunke;1359383]
"On the transformer I get 317 and 326 ohms across the two sections and 9.6 ohms between the two. Infinity to chassis. Does anything sound off?" Sounds OK. Your yoke readings sound OK too, but make sure the vertical windings aren't shorted to the horizontal windings or to ground if there is a groundwire to the yoke. Do you have the right B+ voltages on the vertical circuit for the Osc. and the output? Best Luck, Cliff |
