Old 09-18-2007, 11:49 PM
dr.ido's Avatar
dr.ido dr.ido is offline
NTSC 4.43 is produced by some PAL VCRs that have an NTSC playback function. It's cheaper to build than a true multisystem VCR and most multisystem TV's (and some PAL only sets) will display it.
Old 09-19-2007, 02:51 AM
Telecolor 3007's Avatar
I love old stuff
I know that no country used for television N.T.S.C. 4.43
Cuba now it's using SECAM
But anyone ever seen an N.T.S.C 4.43 tape?
Sailor Moon
Old 09-19-2007, 06:59 PM
I believe this is not technically what is generally known as NTSC 4.43. It is 525 60 Hz with PAL 4.43 color. Even an old PAL only TV will display this in color, but you have to adjust the vertical hold. The reason you can't record this on a PAL VCR is because it's 525 60Hz instead of 625 50Hz. You need a VCR with a standards converter if you want to convert a tape to PAL.
NTSC 4.43 is 525 60Hz with NTSC color encoding, but with the color subcarrier at 4.43 MHz.
There is no such thing as an NTSC 4.43 tape. I just confirmed this with my miltistandard VCR. A recording made in NTSC, or NTSC 4.43 is identical.
Old 09-20-2007, 11:40 AM
colorfixer's Avatar
I had a Sony PVM-1270 that was PAL, SECAM. NTSC 4.43. With some help from the local branch of Sony, I simply changed the reference crystal and did some twiddling to make it work on '3.58.
Don't know if it made the PAL mode inoperable though.
I really miss that monitor...
Old 09-21-2007, 12:34 AM
dr.ido's Avatar
VCRs that playback NTSC tapes as PAL 60 came later. The earlier decks output it as NTSC 4.43.
Some jungle ICs (usually found in cheaper TVs from the early 90s or so) can decode PAL or NTSC, but can only handle one subcarrier. The PAL model gets a 4.43MHz crystal and can display NTSC 4.43. The NTSC model gets a 3.58MHz crystal and can probably handle PAL-M.
I've yet to see a true multisystem jungle IC that handles PAL, NTSC and SECAM. The few SECAM capable sets that I have seen use a seperate IC for SECAM.
Another non-standard NTSC variant is produced by some "international" model Apple ][e computers. I don't remember what the subcarrier was, but it wasn't 3.58MHz and I don't think it was 4.43MHz either. I do remember I had to change the crystal in the monitor to 3.58MHz to get to play my NTSC 3DO games in color (back then I didn't have any multistandard monitors/TVs). I think Apple just wanted to make sure people bought their monitor.
Old 09-21-2007, 01:07 AM
colorfixer's Avatar
The 1270 I had only had PAL, Secam, and NTSC 4.43. The 1271 I worked on at the office had all 4 "systems" including both NTSC and NTSC 4.43.
It struck me as really odd at the time since I remembered the one I had before having 3 leds on the status panel for system, and I thought, why would they have made different models for what was supposed to be a multi system monitor.
Anyone have either one of these beasts for sale in the pacific northwest?
