Old 09-16-2007, 07:03 PM
roundscreen roundscreen is offline
Originally Posted by TVtommy View Post
From my recollection(which ain't as good as it used to be), Motorola started production on the Quasar in 1966 but it went on sale advertised as a 1967 model. There were two different chassis numbers using the same modules, TS-915 & TS-919. The 915 went in the large floor model console (Works in a drawer) and the 919 went in the 21 inch table model cabinet (Works in a cage)( vacuum tube Hv rect.). In later years I have seen a lot of xstr leakage problems in the video i.f. and agc sections. They ain't real fussy about sub. types, 2n2222 seems to work well when replacing the NPN's and an equivelant PNP type for the other flavors. Moto started production of the QuasarII sets in 1969 and put them on sale as 1970 models. They were solid state sets except for tube type horiz buffer/vert osc., vert out., damper, & horiz out although they went to a solid state stick rect. for the Hv. These are chassis no. TS-929(table top-cage chassis) & TS-934(console-works in a drawer) with the same modules(all new & no carry overs from TS-915/919). Sometime around 1972, the QuasarII went all solid state with the addition of a switching Lv power supply module(now TS= TS-938). To make the horiz section ss they brought forward the F panel originally used in the TS915/919! This was already a reliable piece, Moto just updated the HOT(s). To make the vert. sect. ss, a new module was designed, the VA. This was carried forward into the next gen. of ss chassis, the TS-942. The TS-938 has the distinction of the first American production set to use a switching type power supply to eliminate the bulky power xfmr while still retaining the elec. isolation virtues of it. Now they're in everything from coffee makers to computers. The TS-942 chassis family, btw, were the last ones Moto designed completely before selling Quasar to Panasonic. Panasonic stayed with the works in a drawer concept for quite awhile putting more and more functions on ever larger growing (and expensive) modules until they too went to unitized chassis in the 80's like everybody else and finally in the end, Quarsar was just a re-badged Panasonic. It could have been worse, I guess? Thanx for letting me bore everyone with this over-extended Quasar-as-I-know-it story.
This info is not boring at all. You ans many questions that I could not figure out. I am seeing two different dates on this set, 1966 and 1968.
One other thing you pointed out was Quasar was a name given by motorola not panasonic. I thought quasar came into play after panasonic took over.
Another interesting thing is there is a chassis coded F 23ts-915 that has a ac line regulated power supply that is connected to the primary of the power transformer. It makes sense to me cause when the air turns on in this house, The picture on my set would cave in. This must have been a correction for this chassis to calm down picture change when the ac line voltage would go lower or higher.
When I was trouble shooting the power supply in this set I did notice a vary strange design with the 35 volt supply line. There is a 35v tap off the secondary winding of the power transformer. The voltage from that tap goes through two choke transformers and two 500 uf caps and then on to the panels that use the 35 volts. When I was checking the voltage line with the scope, The wave form matched the picture on the schematic so I did not worry about it. My question is how can the ac be remove from this circuit with out some kind of rectfier-diode in this circuit. Would any one know the name of this design?
It is funny, I have had this set for many years and never thought what a cool set this really is. Do any of you guys own a 67,68 motorola works in a drawer?
If so I would really like to see it.
Thanks
Ed
