Old 08-25-2007, 02:28 PM
It would probably be worse to daisy-chain those preamps than to just get one powerful one in the first place, because they are all intended for the same input level, more or less. Otherwise, it is like hooking a stereo amplifier to the speaker terminals of another stereo and hoping to get the combined output of both amplifiers.
If you want to make your plan work, a tuned antenna is very important. The length you want in feet, for a 1/2-wave dipole, is 468 divided by the frequency in megahertz, or just under 7.5 feet for 63 MHz (the center of Channel 3). You could cut two pieces of wire, each about 3.7 feet long, and attach them to the center and shield of a piece of TV coax, then mount the whole thing horizontally, as in the Wikipedia article for dipoles.
http://en.wikipedia.org/wiki/Dipole_antenna
That should work far better than just connecting random pieces of wire.
