Old 08-20-2007, 05:58 PM
Dan Starnes's Avatar
Gizmo Nut
12W6 tube sub?
Messing around with my Emerson 1168A. The vertical is sensitive to scene changes while viewing. VO tube is a 12W6 and I tried a 12W6GT,, in which it did not like. Vertical was way out with the switched tube, so I put the old tube back in. Worked like always. I also have doubt as to the health of the sync tube, which has not arrived. The one thing, the 12W6GT tube got hot very quick and it is a NOS tube. Maybe faulty tube, or not a good substitute?
Dan
Old 08-20-2007, 06:09 PM
David Roper's Avatar
console lover
Is it a metal tube?? In a glancing search I didn't see any reference to a metal 12W6 but did see 12L6 which, being a variant of 25L6 (not 6L6), would differ from the 12W6 in designation only, they're really the same tube. In any event, the electrical specs between metal/GT/G/whatever tubes of the same type will certainly be identical and in that application I'd expect them to sub interchangeably.
tvontheporch.com
Old 08-20-2007, 06:37 PM
polaraman's Avatar
polaraman polaraman is offline
<--1956 300B
12EN6 And 12L6GT
Polaraman
On the Bench: Master's Degree Thesis!
Old 08-20-2007, 06:57 PM
Gizmo Nut
Nope, not a metal tube.
Dan
Old 08-20-2007, 07:52 PM
console lover
A 12W6 in a glass tubular envelope is a 12W6GT with an abbreviated designation. The tube you swapped in is probably no good. Don't you have a tester?
tvontheporch.com
Old 08-20-2007, 08:52 PM
Gizmo Nut
No dont have a tube tester yet. It is on my need to get list for sure.
Dan
Old 08-21-2007, 12:19 PM
kx250rider's Avatar
REAL TVs have TUBES!
That's not an expensive tube... I'd just get another one from someone here, or from Antique Electronic Supply http://www.tubesandmore.com/ . They've been around for 20+ years, and have fair prices and guarantee their tubes.
Charles
Old 08-23-2007, 05:34 PM
Gizmo Nut
Duh on me,, one of the pins is missing on the new tube. Charles I will go to the link you provided.
Thanks guys
Dan
Old 08-23-2007, 08:39 PM
console lover
Don't tell me...pin #1?
Pin #6?
tvontheporch.com
Old 08-23-2007, 08:56 PM
Gizmo Nut
Nope,, #4 is gone. Goof up when it was made? I do believe it is NOS.
Dan
Old 08-25-2007, 09:33 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
One ePay seller I've had a good experience dealing with has a few12EN6's in his store as well, 1 Big Deal; even the usually pricey CJ's Tube Collection isn't asking much for theirs. (No, I am NOT connected with either of those sellers in any way).
