Old 08-17-2007, 01:51 PM
I'm sure a new fuse will fix the problem. There should be 6.3 VAC across pins 1 and 14 of the CRT. Use caution as there is 132 VDC potential between pin 1 and ground. I believe the reason that they placed a high DC potential on the filament was to minimize tube arcing. I also agree that this was one of the best Magnavox color sets made. Would your tuner by chance be the type that has those three colored levers and a yellow knob for programming the channels. One would almost have to have a degree in rocket science to program that thing. It would probably be worth getting that Sams for that set; but, I wouldn't be too quick to pay the $20 something Sams wants. I'll look through my extra Sams and if I have an extra copy; you can have it. You might check epay as well as some older TV shops. Most shops would probably be glad to sell you a Sams that old because most of them would laugh if someone brought a set that old in to be repaired.
