I pulled the Sams (1815-1) on this set, and, there is a two amp fuse in the CRT filament circuit. It's very possible that this fuse is open. The CRT gets it's filament voltage from the main power transformer. It's either going to be a blown fuse, an open filament winding, or an open CRT filament. Even if the CRT is bad; don't scrap the set just yet because I'm sure a good used tube can be found.
