Old 07-08-2007, 10:27 AM
Where is it arcing to? The HV rectifier socket should be completely containd within a plastic cup to prevent arcing. If it's arcing through a crack, or hole in the cup, this should be repaired, or replaced. It's not a bad idea to insulate things with silicone, but in this case, it shouldn't be the only thing to prevent arcing. You can get special silicone designed for HV insulation, but I've never had any trouble with GE silicone II.
