Yes, the 12HG7 is a 9-pin miniature base
(the larger 9-pin like used on the 6JE6 output tube is called a Novar base) I would double check the socket...if it is not burned and is in one piece it is likely OK...more often the problem is microcracks in the solder attaching the socket to the board if the tube appears intermittent. |
What is the name of the base on the 6gf7 vertical tube. Would that be a novar base. Thanks Ed |
Thanks, both of you, for the info......yep, I had re-soldered all of the socket connections before to be sure that wasn't the problem....Now when I stick the tube in, there is a little bit of sparking going on with one of the pins.....the plastic is cracked and getting brittle.....does this seem like a socket issue itself now? I remember when I put the new tube in that socket (along with all new other tubes) it performed like new for a few days. I think I had been maximizing all of the settings and making sure all the new tubes were fully in their socket and then the problems started. Had to jigger the 12HG7 just right for the set to work, then it just kept getting harder to "find that just-right position"....Then it just lost the picture and sound altogether. Now I have a dimly lit screen with no sound or reception--ironically just as it was before I replaced all the tubes....! Any theories would be greatly appreciated......as I am an amateur in comparison to the AK mindtrust. thanks |
Also, which of these 9-pin mini's would you recommend to fit this set?
Thanks. SOCKET, 9 PIN CERAMIC, HIGH QUALITY Top mounting tube socket. 7/8" chassis hole diameter, 1 1/8" mounting centers. SOCKET, 9 PIN, MINIATURE, BELTON 9 pin miniature Belton socket. 1 1/8" mounting centers, fits 3/4" chassis hole. SOCKET, 9 PIN, MINATURE, BAKELITE, BOTTOM MOUNT RING Bakelite molded socket has bottom mount ring. 3/4" chassis hole, 1-1/8" mounting centers. SOCKET, 9 PIN, MINATURE, SADDLE TYPE, PLASTIC Phenolic top mount socket fits in a 3/4" chassis hole with 1-1/8" mounting centers. SOCKET, 9 PIN, MINIATURE, CERAMIC Top or bottom mounting ceramic socket fits in a 7/8" chassis hole and mounts with a ring on 1-1/8" centers. SOCKET, 9 PIN, COMPACTRON, MOLDED SADDLE Compactron socket for 6LQ6 tubes and others like it. NOS micalex socket is bottom mounting and fits in a 1" chassis hole. Mounting centers are 1-7/16". SOCKET, 9 PIN, COMPACTRON, MOLDED All molded sompactorn socket bottom mounts in 1-1/16" chassis hole, 1-5/16" mounting centers. SOCKET, 9 PIN, MINIATURE, STANDOFF CERAMIC PC MOUNT White ceramic PC mount socket. SOCKET, 9 PIN, MINIATURE, PLASTIC, PC MOUNT White plastic PC mount socket has 3/4" tail diameter. SOCKET, 9 PIN, MINATURE, CERAMIC, PC MOUNT, GOLD PINS PC mount ceramic 9 pin miniature socket. Gold pins. SOCKET, 9 PIN, COMPACTRON, PC MOUNT Socket rests on shoulder of contact tail, providing an air gap for cooling. For 1/16" circuit boards with bottom circuitry. SOCKET, 9 PIN, MINIATURE, PC STANDOFF, BLACK 9 pin miniature, pc mount-standoff, black socket. 13/16" tail diameter. SOCKET - 9 PIN PC MOUNT STANDOFF Minature, PC mount stand off (Belton). 3/4" tail diameter. SOCKET, 9 PIN, 3/4" CHASSIS HOLE, 1-1/8" MOUNTING CENTERS Black plastic. 3/4" chassis hole, 1 1/2" mounting centers. |
