The zenith chassis have plenty of room under them. If you want to save money, use individual caps for the power supply and don't worry about trying to find replacement filter cans. If you haven't worked on electronics before, don't fear. Edit your profile to show your location and someone may be nearby to help you out.
The caps to replace are the electrolytic and wax caps. Most sets of this recent age don't have wax caps in them anymore, but you can never be sure. Re-capping the set may only take you an hour or two if you already have the parts on hand. If you don't have them yet, then I recommend either justradios.com or tubesandmore.com for replacement capacitors. I believe most of this chassis just unplugs from everything else. 4 bolts to remove the chassis from the cabinet. Just make sure to DISCHARGE THE CRT before trying to remove the chassis, or you'll get a BIG shock when trying to disconnect the CRT from the high voltage cage. Attach a clip lead to the chassis, and the other end of the lead to a long, well insulated flat-blade screwdriver. slip the screwdriver under the rubber anode cover and move it inward until you feel it stop . It should be touching the anode now. let it sit there for a minute or more to fully discharge the high voltage. Now you should be able to take the chassis out without fear of shock. After you pull the chassis, I would also recommend checking to see if there are still residual voltages on the power supply filter caps before trying to unsolder them. if there is anything more than 500mv, discharge them using a 100 ohm 1/2 watt resistor to the chassis. Otherwise you could get a big spark across your soldering iron when trying to unsolder them. Also be very cautious of polarity. Some of the filter cans may have a negative ground or positive. installing power supply capacitors backwards may cause them to overheat and explode or smoke the chassis. Overall, the set is well worth the trouble. Zenith TV sets by far are the most reliable and produce the best picture of any vintage color set. Get it working properly and it will serve you well.
Jordan |
