Old 06-15-2007, 06:40 PM
matt_s78mn's Avatar
matt_s78mn matt_s78mn is offline
Originally Posted by RCAkid View Post
A few months ago, I was fortunate enough to bring home a "new" G-2000. This set had no previous owner. When it was brand new, it was floor demo for a TV shop in Wisconsin that closed up. The set has all its hang tags, manuals, warranty cards, name plate sheet and even the remote is still wrapped in its felt bag attached to the back of the set. The cabinet has only one ding in it on the off white portion. The chassis seems to have little time on it as, except for a very fine layer of plain old dust, it is in pristine condition. Still shiny after all these years.
Wow that's really awesome. I also picked one up a few months ago at an auction for a tv shop in Iowa that was closing down. It sounds as if yours is in much better shape than mine. Mine has several dings in the white trim and on the top because it lived the last few years in the service department of that tv shop, with stuff piled on top of it. I have the owners and technical manuals (that came with the set in the pouch on the back.) And I also have an RCA Service manual for it. BTW, if you need anything out of the service manual (File: 1969 No. T19) just let me know and I can provide it for you. If you get a chance, post some pictures of your 2000 on here.
The set has been in regulated storage for nearly 30 years and was powered up about 3 years ago. At that time, I was informed, it had a good picture but it was not a full raster suggesting a failure or bad module connection in the vertical circuit.
While this chassis, albeit transistorized, is very similar in layout to a CTC-21 or 38, it is not a tube set and I am uncertain about powering it up with a variac. I am not certain if this set has a switching supply or some hybrid form of one since the tuner, etc is electronic. I know with the old Zenith space command 300/400 sets, there was simply a separate receiver that operated independantly of the main chassis.
If the set was powered up 3 years ago and operated fine although it had the vertical problem, I agree with WA2ISE that you could check the electrolytic cans to see if they measure what they should. But, you should just be able to power the set up normally and do the touch test on the electrolytic cans to see if they are hot or not. This set is new enough that you don't really have to worry about bumblebee or wax paper caps.
I don't have the data in front of me right now, but I believe the CTC-47 chassis (which is the 2000) and the CTC-46 chassis are very similar. Both chassis are solid state, with the 46 being RCA's first. The main differences between the two being the HV section of the 47 is completely solid state, whereas the 46 has a HV Rect tube. and of course the tuners are different, given that the 47 has the new electronic tuning.
I know there are a few of you who have worked on these sets in the past and I was wondering if you had a good procedure for bringing this set up for the first time. I just want to be very careful with this set so I can see where I am before I dive into it and start cleaning module contacts, recapping, etc.
Thanks in advance!
I will be very interested in your progress with the set because mine has recently developed some issues and will be going on the bench soon, so we'll both be working on our sets at the same time. Mine has quite different issues than yours though. It has a ringing or smear in the chroma, so that the blue and green are smeared to the left and right, and the tv will slowly loose chroma so that if the set is on for about a half an hour the chroma will be gone and you're stuck with a black & white picture. Also the motor that turns the UHF tuner does not work.
