Nice finds! Was that sale near you, maybe in one of the old 40s-era houses around there? I can see in the photo that you've already had the 4-lead cap update. But you still have the old 9-92 vertical module. That should get swapped for a 9-147. Otherwise it will have unstable vertical height, and you'll be adjusting it alot...
ALSO CAUTION on that ChroII... Don't try to tip it forward! I've learned that the hard way. You have to pick it up, and lay it on its face, or the front pedestal can crack.
Charles
