Service menu
Those numbers are OCTAL. this is a combination of numearls, and digits, used by some computers, for data. it starts off a 01, goes through the digits, then 1a,or so, and then so on. some digital menus use this, (panasonic, for one.)
still, it is adjusted the same way. if your brightness is too low, and will not come up with the menu, try the screen control probably on the crt board. BE CAREFUL. do not raise the level too high, or you will get retrace lines. raise the level till you get retrace lines, then back off, till these disappear. do this wiht the brightnell at minimumm, as sometimes the lines are hidden by bright scenes.
