OT, found a Scope
Picked up this German made Hameg dual trace 20mhz scope today, dirty but it appears to work!
This should be good for old TV work?? It's didn't come with any probes and I don't know what I would need, any suggestions are welcome.
Whie a good used Tek is hard to beat, that scope should be fine for most TV work. Get a pair of good 10x probes for general use. These will give you the best bandwidth and won't load down the circuit under test.
Near the input jacks, it will tell you what the input capacitance is. You need probes that can compensate that capacitance. Check before you buy. Get some with a little more bandwidth than your scope can do.
John |
