That sounds a bit off... While not impossible, it's unlikely that the Flyback would fix itsself when cold. I bet the repair guy just didn't want to put the time into it, figuring you can't find a flyback. Also, it almost HAS to get super-blurry and also shrink from the sides or blow up large ("bloom") before fading out if the problem is loss if high voltage. If it isn't doing that, then you might have a video or CRT filament supply problem. Has anyone actually measured the high voltage after the picture fades out?
If the high voltage is "fading away" as it stays on for an hour, I bet something is changing value (cap or resistor.) Just my opinion.... Charles
Collecting & restoring TVs in Los Angeles since age 10 |
