I would think that the A/V output to your TV should work fine. When you press play, does the time advance, and does the disc seem to play?
If not, then the pickup could be on its way out or their could be a transport problem. if the time is advancing like its playing, and you still have no A/V check your cables and make syour your TV is on the correct input. Try the cable with another device like a VCR. At worse the unit has a faulty audio video output.
Jordan |
