That looks like very similar to the remote chromacolor II I found last week. What's the small rectangular object just above the channel display? Mine just has the Zenth logo across the top.
Those Pana-Colors aren't bad TVs once you fix all the bad soldering and replace some bad small electrolytics. They also used a damper tube that tended to fail and take out the HOT. Check for bad soldering on the plate caps to the HOT and damper. Mine were both badly soldered. |
The square thing is a button for the Color Sentry. That chroma color II set is a tank!! it weighs 50 pounds. Got it for $10 at a thrift store.
Pana-color set works real well. I have yet to take off the back to check it out. polaraman |
