Old 09-30-2006, 06:57 PM
jbpollock's Avatar
jbpollock jbpollock is offline
AK Member
Hallicrafters S-53A
I picked up a Hallicrafters S-53A table top shortwave radio at a garage sale this morning. Brought it home and the power cord was only about a foot long and obviously repaired. Went to plug it in and got a large spark between the two sides of the plug. Got it plugged in despite the spark (stupid I know) and it did power on. No sound, and only left it on for a minute. It looked like all but maybe 1 of the tubes was glowing. Anyway, the selector switch on the back was set to headphone rather than speaker. I went to plug it in again to see if this was causing the silence, but got another spark and decided not to plug it in again. (It was turned off by the way).
Anyway, any opinions on wheter or not a new power cord will solve this problem?
Old 09-30-2006, 07:06 PM
Tom Bavis's Avatar
Audiophool
You'll want to replace the leaky caps (which is probably ALL of them) before using this. Owners manual is here: http://bama.edebris.com/manuals/hallicra/s53a/ - I see alignment listed, I assume there's a schematic as well.
Old 10-01-2006, 11:21 AM
jbpollock's Avatar
AK Member
Thanks for the link. Those are great manuals.
Old 10-01-2006, 12:08 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
I have one of these receivers that I have restored and have been using for e few years now. They work great and are well worth the effort to bring back. You will want to replace ALL paper caps and electrolytics. This is a good transformer powered set so you don't want any parasitic loads. I have a schematic for this radio and if you need any information, please let me know.
I will start you off right by giving you the schematic.
On mine, I restrung the dials, replaced the front panel toggle switches and much more. It was well worth it. The S-53A is one well built radio.
Old 10-01-2006, 12:14 PM
compucat's Avatar
1949 Motorola 9VT1
S-53A Schematic
The schematic file is too large to upload. If you need it, let me know and I can e-mail it to you.
Old 10-01-2006, 12:36 PM
jbpollock's Avatar
AK Member
Compucat, thanks for the offer, but the link that Tom Bavis posted above has a nice scematic.
Regarding the capacitor replacement, they are listed in the manual as either
1) Ceramic
2) Tubular
3)Trimmer Assembly, 5 sections, antenna stage and Trimmer Assy. , 6 secs., oscillator stage
4)mica or silver mica
5) Folded Paper
6) Electrolytic (only one- the big can with 3-capacitors inside)
Of these, obviously you mentioned that you replaced the folded paper and electrolytic....but the rest are fine? I am not clear on what the manual means by "tubular"
Thanks!
Old 10-02-2006, 08:20 AM
compucat's Avatar
1949 Motorola 9VT1
The tubulars are most likely plastic encased paper caps. It has been a while since I worked on mine. They should be replaced. The ceramics and micas should not be bad. The trimmers should not need replacement unless they are physically damaged.
Also, you will want to check and/or replace any high value resistors in the power supply and audio output stages. Resistors rated at 1 Megohm or above tend to drift upward in value.
Old 10-03-2006, 09:19 PM
jbpollock's Avatar
AK Member
I took the radio out of its metal cabinet tonight, and you are right...the tubulars are paper...coated with wax or soft plastic. Access may be a little tight in some places, but no worse than any other table top radio, I suppose. Thanks again for the advise. I will update when I manage to find some time to replace these parts.
Old 10-04-2006, 12:43 AM
I would definitely replace the 3-section electrolytic cap as a matter of routine. As for the spark when you plug the receiver into AC power, that is a red flag if I ever saw one--there is definitely a short somewhere, and probably close to the input to the power transformer. I'd replace the cord first, before plugging the receiver in again. The S-53 dates back to at least the 1950s; yours may well have a dry-rotted cord that should have been replaced long ago--you will get a huge spark as you described if bare wires from the cord short against the chassis or each other, although I'm surprised the house fuse (on that circuit) didn't blow as soon as you saw the spark. I had a floor lamp in my apartment that shorted out from the same cause (bare wires shorting against each other) a few months ago; I saw a huge spark at the base of the lamp, after which the circuit breaker in the basement of the apartment building tripped.
When you had the receiver plugged in and switched on, did anything on the chassis (power transformer, filter caps, etc.) feel abnormally warm after the set had time to warm up? If the transformer felt extremely warm or so hot that it would burn your fingers, pull the plug immediately. The transformer is either shorted (a high-resistance short will not blow a line fuse, but a low-resistance short will) or else something in the radio is drawing much more current than it should. If the filter caps are warm or hot, yank the plug as well, as the capacitor(s) is/are dead shorted--these capacitors are in a position to blow the house fuses (because they are connected effectively directly across the AC line) if they short.
If the short in your S-53 were anywhere after the AC input, it should have blown the receiver's own fuse if it has one, which it should--Hallicrafters communications receivers were all equipped with a line fuse that will blow in case of any major low-resistance short, such as a shorted rectifier tube or a short in the power transformer, to name just two such shorts that should indeed blow that fuse if it's the correct size.
As to all but one of the tubes glowing when you had the receiver plugged in, that's a dead giveaway that the unlit tube is dead as a doornail and must be replaced. In fact, the unlit tube may very well be the reason why the radio won't work (if the dead tube is in an audio stage, for instance, you won't hear a thing from the speaker). However, until you at least replace the cord, don't plug the receiver into an outlet. As it is now, the radio has a dangerous short that must be found and corrected (not to mention being a shock hazard) before the set can be used.
Kind regards,
Old 10-04-2006, 07:38 AM
Well, here's what my Fred Osterman "Shortwave Receivers:Past & Present"-the "Bible" of this stuff- has to say...S-53-1948-1950, scarce, 8 tubes, was about $80 when new. The S-53A was made from 1951-57, is fairly common, & was about $90 when new. Doesn't look like there's any real difference...
Old 10-04-2006, 08:17 AM
compucat's Avatar
1949 Motorola 9VT1
The differences between the S-53 and the "A" version are that the "A" has civil defense markings on the dial and uses miniature IF cans. The S-53 has no CD marks and uses full size IF cans. Other than that, they are the same radio.
Old 10-04-2006, 11:50 AM
jbpollock's Avatar
AK Member
Jeffhs, after taking the unit apart the cord is even more pitiful than is appears and could very easily be shorting on te cabinet. There actually is no fuse in this radio that I could find. The power cord hooks directly to the rectifier tube and then off to the power supply.
If I wanted to add a fuse for safetly, where would it go?
When I did have it turned on, nothing felt abnormally warm, but I only had it on for 1-2 minutes. Is there a way to determine if the power tranformer is good before I replace all of the capacitors?
If I am able to get this radio working, I do want it to operate safely. Is it advisable to send this off to someone who knows what they are doing or is it all pretty straight forward (I don't want to burn my house down or "electrify" my friends and family)
1951-57. I guess this radio is from late in the 53A production run because it is stamped Mark II on the chasis.
Old 10-09-2006, 11:26 AM
NikkoUser's Avatar
NikkoUser NikkoUser is offline
AK Member
I don't think you should get all that excited over that S53-a. I used one 40 years ago as a Ham Radio Novice. It worked but just barely. It was just another in a long line of Hallicrafters cheap radios that they were producing. If you look at the dial, there's only about 1/2 inch of dial space to cover the 40 meter band. It did work but there are many more receivers out there that have more value. Anything with "half moon" shaped dials will be more valuable.
Old 10-09-2006, 01:36 PM
compucat's Avatar
1949 Motorola 9VT1
The only thing about this radio that isn't that great is the BFO. It is practically useless for receiving voice SSB transmissions. It was obviously designed for use with CW code transmissions. As a shortwave program listening receiver, it is excellent and I've had good results with mine using a 12 foot piece of wire run along the floor.
Also, there is no line fuse in this radio. When I got mine, a replacement line cord had been poorly spliced in by hand (no solder) to the tube socket and the wire covered with electrical tape. I completely diassembled that radio, did a full cleaning and restoration and corrected a few hack repairs in the process. Now it is on its second fifty years of reliable service.
Old 10-09-2006, 08:35 PM
jbpollock's Avatar
AK Member
Well, I replaced the power cord yesterday and now the radio is working pretty well. Last night I was able to pick up AM stations from Atlanta, Houston, Chicago, and Kansas City. Shortwave from Cuba, Venezuela, Canada, Isreal, China...lots of others....plus that crazy Spanish counting lady.
Will need to recap when I have time. The unit runs somewhat hot so hopefully that (and replacing the high value resisitors) will take care of it (Although I don't know how hot it is supposed to get)
The coarse bandwith adjuster is fairly...well...coarse. But there is also a fine tuning knob that makes it easy enough to tune in stations. It meets my needs as someone who isn't a dedicated shortwave listener, but does enjoy playing around with it from time to time and getting different perspectves on news and world music.
