Old 04-17-2005, 10:21 PM
veg-o-matic's Avatar
veg-o-matic veg-o-matic is offline
Huh?
Unhappy Aw, crapdoodles, here we go again...
Okay, so I fired up Laura and noticed that while the sound came on normally, it was taking a long time for the picture to show up.
Dang it, this is what I got.
Is this another capacitor that has to be replaced? Please, couldn't it be a tube this time? I'm good at those!
Funny thing is, she worked just fine last week. I haven't been watching much TV lately, so she only gets turned on once a week or so.
Any thoughts to help a poor fool like me?
Thanking you in advance!
Old 04-17-2005, 10:57 PM
reeferman's Avatar
Remember all the experience you gained the first go around replacing caps? You know the rest of the reply! Phil
Old 04-17-2005, 11:56 PM
Looks like the pincusion circuit isn't working right. That's ususally the circuits electrically near that small transformer with three bobbins fed by the horizonral and vertical deflection circuits. Maybe a trimpot went open?
Old 04-18-2005, 05:12 AM
Aussie Bloke's Avatar
Aussie Bloke Aussie Bloke is offline
I once had a dream of a colour TV with concave sides like the picture on your telly. Anyways hope you get the problem fixed, nice looking set.
Cheers
Troy
AUSSIE AUSSIE AUSSIE!!!!! OI OI OI!!!!!
Old 04-18-2005, 05:29 AM
jstout66 jstout66 is offline
It looks like a cap to me. Also, IIRC a round screen set has no pincushion transformer or correction. That wasn't needed until rectangular screens came out. For RCA the CTC17 chassis was the first to use that.
Old 04-18-2005, 07:25 AM
Chad Hauris's Avatar
Looks like a main power supply problem to me...looks like a case of low B+ voltage. May be leaky or open caps.
Chad Hauris
Old 04-19-2005, 08:26 AM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
filter cap going bye bye
looks like the 160@250vdc filter cap is bad they didnt use pin cushion correction on the roundies, didnt need it
[IMG]
Old 04-26-2005, 11:26 PM
RVonse RVonse is offline
Yes, that is definately a power supply cap and you can easily isolate which one it is simply by putting a good one across the old one.
Old 04-27-2005, 09:31 AM
Huh?
Which I tried just the other night, to no avail. Figures.
But here's a question: what are the chances that a new cap will go bad within a few months? Pretty slim, I would suppose.
I ask because oldtvman suggested it might be the 160@250 cap, which is one I replaced several months ago. It's also one I didn't bother checking the other night. Guess it wouldn't hurt to give it a try. If one of the solder joints went bad on this cap (I've moved it around a little to get to other things under there), would that cause the short-wavy-picture problem? I'm a little irritated with this because it's one of those cases where "it worked just fine yesterday."
Old 04-27-2005, 11:44 AM
Old 05-01-2005, 08:24 PM
roundscreen roundscreen is offline
I like your zenith. good looking set. Check the caps you put in . I have had new caps go bad before. Any time I put in new caps I will check to see if they get warm.
If they do I will replace it with a higher voltage cap. When you use a roundie as an every day runner they will give you trouble. Some times it has taken me 6 months to get all the bugs out. But when you do, The set will run trouble free for years.
Old 05-02-2005, 12:06 PM
kc8adu's Avatar
kc8adu kc8adu is offline
one of the rectifiers cound have gone open.
seen it in a 16 a while back.
email for more info
Old 05-06-2005, 11:09 AM
NIPPERTHEDOG's Avatar
NIPPERTHEDOG NIPPERTHEDOG is offline
Banned
Nice retro TV
Beautiful Zenith!!!
Look for an experienced TV repair man in your area if problem persists. I kwow this isn't recommneded route, but may have advanced problem that's hard to find. Think about that option, I don't know what you have for repair equipment, sometimes you look back and wish had someone just fix it. Good luck, again NICE SET.
Old 05-07-2005, 12:28 AM
mbates14 mbates14 is offline
with the darker shade of image in the center, it looks like low B+ to me, and could be caused by a bad cap or near open resistor. test all the parts in the power supply circuitry.
Heck, ive seen alot of new caps go bad, especially the case with nichicon caps. They suck.
Old 05-07-2005, 08:56 AM
kc8adu's Avatar
like the ones i am replacing on g5 midplanes and dell gx270 mobo's?
badcaps
email for more info
