Old 08-13-2023, 04:10 PM
Chris K Chris K is offline
B&W CRT Question
Hi all. I have a 10BP4 with strong emissions down to 4 volts, no shorts but the cutoff is poor. How does a tube get this way, what is going on inside the tube that might create this condition, what kind of picture quality can I expect and is there anything that can be done to remedy it?
Thanks VKers!
Old 08-13-2023, 06:48 PM
Polaraligned's Avatar
Polaraligned Polaraligned is offline
The cutoff test measures the effect of the control grid. If you have poor cutoff, the contrast may be poor. I would just try the CRT in the set and see how it performs. The tester may be lying.
Old 08-13-2023, 07:49 PM
I had a tube with absolutely no cutoff in a RCA set and it actually worked ok and looked fine.
