Old 12-24-2022, 11:45 AM
CBS Columbia
What would cause a faint white line in the center of the screen at the 12 and 6 position up and down.
Old 12-24-2022, 03:27 PM
Complete failure of horizontal sweep while still having some HV and vertical sweep is very unusual, but it can happen, but w/o schematic or MO #, who can tell.
CBS Columbia is rather vague.
Old 12-24-2022, 04:21 PM
I already recapped this set works really nice but between like commercials you can see bearly see the line top to bottom. It has vertical and horizontal produces a nice pic I’m probably not going to worry about it but was wondering.
Old 12-24-2022, 06:23 PM
OH that.. is caused by a weak horizontal output tube, most of the time. my Stromberg Carlson BW set did that when cold until I replaced it.
Old 12-24-2022, 07:16 PM
A weak hot even though it’s got a bright picture and perfect hv.
Old 12-24-2022, 07:19 PM
yes, a faint line in the center, a weak horizontal output tube is the first suspect.
Old 12-24-2022, 07:20 PM
It could also be a horizontal drive line, caused by an incorrectly set horizontal drive control.
If the line is kinda shimmery like it has white noise in it then it's barkhausen and might be fixed with a well placed magnet on the H output tube.
No picture=guess work diagnosis.
Old 12-24-2022, 07:54 PM
A 'quick & dirty' test for a borderline HO tube is the "seven seconds off" test. Turn the set off for 7 seconds, then back on. If the width is slow to fill back out, the tube is borderline. Same test will show up other borderline/weak tubes like H oscillator, vert out, color oscillator, RF amp etc.
Old 12-26-2022, 04:48 PM
Yes but if its a true drive line / fold over I would track it down or you may
eat up the H out. Barkhausen & snivets are quite distinctive. Magnet works BUT!
The shop bought out a Radio Shack clone store. They got loaded down
with IEC & Raytheon ( red arrow ) tubes, probably 1000 of them. Cost us 5 cents each. Every H out had problems especially barkhausen. Along
with that there were JA, Euro & one chassis US tubes that were useless.
In the end 5 cents was no bargain !
So bottom line is buy real NOS tubes from real TV makers. Watch out for rest
restuffs, a lot of shops did that. Same with modules. I bet half the
boards on E-bay are duds never returned. The sellers are seldom the
original owners. They are just selling off a clean out & wouldnt know
a dud from a new or rebuilt board. And not GAS.
enuf fer now
Old 12-28-2022, 03:23 AM
Penthode's Avatar
Penthode Penthode is offline
Adjust the hold control while maintaining sync. If the faint line moves in the opposite direction to the active picture, then the line is due to sync waveform edges being displayed during horizontal retrace.
