Old 05-02-2022, 12:12 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
CTC-5 part needed
I need a Burst Amplifier transformer. RCA pt no. 102250. New or used is fine. Super model, not deluxe. I know it's a long shot but who knows
Old 05-02-2022, 01:34 PM
Penthode's Avatar
Penthode Penthode is offline
Have you considered rebuilding it? I had the quadrature transformer fail on my Zenith (crumbled from heat). I found an appropriate new horizontal oscillator coil of appropriate core dimensions, removed the windings and after dismantling and carefully copying the Zenith quad coil, remade it on the new core and it worked great! Similarly remade all the IF coils for an RCA CTC11 and re-aligned it and it worked great.
Might be the best thing to do. (Besides as an interesting diversion, it was fun).
Old 05-02-2022, 02:21 PM
Doug Doug is offline
Did you try Moyer electronics?
You have to ask
Old 05-02-2022, 05:05 PM
DavGoodlin's Avatar
Motorola Minion
You have to ask
Try both of Moyer's stores too, they have different stock at each. Good luck, I would try that first!
-Dave G
Old 05-02-2022, 08:47 PM
Tim's Avatar
Tim Tim is offline
FYI - I checked Thordarson, Merit and Miller catalogs and there are no subs listed.
Tim
Old 05-03-2022, 07:33 PM
mstaton's Avatar
"Book em Dano!"
Moyers is a no go. Maybe someone has a parts chassis. not much hope at this point.
Old 05-03-2022, 07:44 PM
ALso try talon electronics,,,. Etf early television foundation in Hillard Ohio ., And
Parts-link .
Old 05-03-2022, 08:23 PM
mstaton's Avatar
"Book em Dano!"
Neither have it. I'll keep looking
Old 05-03-2022, 08:26 PM
Penthode's Avatar
Just a friendly question: what is wrong with the original one?
Old 05-03-2022, 08:29 PM
mstaton's Avatar
"Book em Dano!"
the coil is torn out of it. Dont ask lol
Old 05-03-2022, 09:00 PM
So do vintage rca tv parts...
The below want a little too much ask if he has the one u need
Then wait till he gives a better offer
Your find others,the individual part numbers won't be listed for a search.
Other than the bay check shopgoodwill.com
Put a watch for vintage parts,tv parts,etc
..https://www.ebay.com/itm/38344801072...UAAOSwF7xeX9NE
Old 05-03-2022, 10:47 PM
Penthode's Avatar
My Zenith 24NC31Z quad coil was toast. It crumbled with heat. It was a fairly critical part because it determined the quadrature subcarier phase and the number of turns and coupling were critical. I had the good fortune and presence of mind to study the crumbled mess and carefully count the number of turns of the primary and secondary and the coupling. As it was resonating at 3.58MHz, there weren't many turns and I simply rewound it on a fresh (stripped) former. The former's previous life was a horizonatal oscilator coil!
Worked a treat.
If yours is really bad, that may be a problem. But A burst coil is pretty basic and many sets used the generic circuit. FYI I see a coil available which you may be able to adapt.
https://www.ebay.com/itm/13302283645...cAAOSwNphcPOHO
The thing is that CTC5 parts may show up. But considering the age, this may be the simpler solution.
Old 05-04-2022, 09:07 AM
mstaton's Avatar
"Book em Dano!"
I can probably make a 105251 part from a CTC-7 work
