Old 02-11-2022, 09:47 AM
tvdoktor tvdoktor is offline
Philco 48-700 assistance
While working on my Philco 48-700, the .4uf 3500v HV filter capacitor shorted and started smoking. Can I use a film capacitor in its place? Any ideas where to purchase an equivalent would be appreciated.
Thanks in advance
Old 02-11-2022, 02:10 PM
Yes film should work fine. You may need to do series pair of 2KV .82uF.
Mouser doesn't have anything close to .4uF at over 3KV... Digikey might.
Old 02-11-2022, 08:20 PM
Hcompton79 Hcompton79 is offline
Possibly something like this, all I could find that was in stock:
https://www.digikey.com/en/products/...RLLckgqMXEdDqA
All I could find that was close, If the voltage rating is insufficient you may need to special order something.
Old 02-11-2022, 10:17 PM
would a Snubber cap work in such a situation?
Old 02-12-2022, 11:05 AM
nasadowsk's Avatar
Damn does run fast…
Be aware this set has the extremely dangerous “brute force” high voltage supply. They are known to kill!
Old 02-12-2022, 11:17 AM
I have never worked on such thing before, so I'm not sure so thus i brought attention to it.
"In modern power electronics, they are commonly found to reduce ringing. A snubber circuit limits or stops (snubs) switching voltage amplitude and its rate of rise, therefore reducing power dissipation."
VS what Electronic M mentioned, using 2 series pair of 2KV .82uF.
bandersentv has done this many times, and would know the most about it.
Old 02-12-2022, 04:06 PM
dtvmcdonald's Avatar
Another possibility, cheap (but a minor nuicsance to construct).
Replace the chain of resistors from the 0.5 uF cap to ground with
a chain of (mostly) 200 volt 1.3 to 2w Zener diodes, with one different voltage to get the
drop across the focus pot right. Then you can use a bunch of 630 volt caps
at say 0.1 or 0.27 uF across triples of Zeners. Because the voltage is regulated, you
would only need a lower capacitance to filter out the Zener noise.
I've used such Zener chains in a couple of TVs and they work fine. Of course
you have to figure out how to construct them.
