Old 09-30-2020, 06:12 PM
ESigma25 ESigma25 is offline
VCR/DVD combos that are actually good?
I'd like to pick up a VCR/DVD combo unit for convenience sake, but I want one that's actually decent. I've found a few that looked promising but, not knowing what to really look out for beyond stuff like "having stereo front panel inputs" I passed on them. What are some recommendations for a decent VCR/DVD combo unit?
Old 10-01-2020, 10:44 AM
Some of the older units that have DVD-RECORDER capability have nice TBCs in them. My Toshiba even has HDMI output.
If you look into the tape door and see metal.parts on the mech it's probably better quality than the plastic nothing burgers they made up until ~5 years ago.
Old 10-01-2020, 10:03 PM
user181 user181 is offline
Naive question: what does TBC stand for?
Old 10-01-2020, 11:09 PM
dishdude's Avatar
dishdude dishdude is offline
Time base corrector. Helps clean up some of the jumpiness in VHS tapes.
Old 10-02-2020, 02:05 AM
beat_truck beat_truck is offline
Definitely not Magnavox or anything else made by Funai.
I had a Magnavox that I picked up for basically nothing. It couldn't even keep the right time on the clock. It constantly gained time and needed reset. With very little use, the VCR turned to crap and wouldn't play or record correctly. The DVD recorder played when I tried it, but I never tried recording with it. I imagine it wouldn't have lasted long either.
JUNK.
Old 10-02-2020, 05:40 PM
JUNK.
The ones that I've been interested in have been ones made by the likes of Panasonic and Sony, been kicking myself for passing on a rather nice Panasonic with gold plated front inputs.
Old 10-02-2020, 11:11 PM
I've had good luck with '90s Sony, Panasonic, and Toshiba VCRs. In fact, I am still using Sonys and a Toshiba. I've never had any of their combos, but they are likely some of the better ones out there. Nothing can be as bad as Funai junk.
Old 10-04-2020, 02:00 AM
Dude111 Dude111 is offline
Analogue is Awesome
I had a DVD/VHS combo once and it was garbage..... VHS playback had a high pitched hiss in it.... Horrible........
Old 10-04-2020, 03:11 PM
I have a Panasonic VCR I bought new in the '90s. It was a replacement for a similar Panasonic that had VCR+; I would still have the latter if it hadn't eaten a tape only a half-hour or so after I recorded a program. I replaced that Panny VCR+ machine sahortly thereafter with another (but the new one did not have VCR+). The new Panny VCR worked well from the time I installed it and still works to this day, although due to the DTV transition, of course, it does not record any longer. I kept the VCR because I still have a bunch of VHS videos I recorded from TV, not to mention a few prerecorded cassettes, in the '80s-'90s (again, long before DTV).
Old 10-04-2020, 09:09 PM
To steer the discussion back on topic, the OP wants guidance specifically on combo units.
