Old 02-08-2020, 06:41 PM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
Atwater Kent Model 35 Troubles
A few days ago I finished the restoration of an adorable little Atwater Kent Model 35.
https://flic.kr/p/2iqxwk1
I chose this model because (1) It fits between my Model 30 and Model 37, (2) I have spare parts to fix almost any electronic deficiency, (3) The shape and the upside-down chassis are somewhat unique, and (4) Most of all, because the TRF is simple enough even for me. Or so I thought.
When I finished the chassis restoration, it looked great:
https://flic.kr/p/2iqAaCr
And it performed well--the best reception and the best audio of any of my radios from that era. And it was loud--had to shorten the antenna to less than 12 inches to have a satisfactory range of volume. Here's a sample of the audio:
https://flic.kr/p/2iqxx2b
But, when I reinstalled it in the cabinet, it didn't work right. Took it out, and it still didn't work right. Here's a before/after audio sample:
https://flic.kr/p/2iqBfHL
I've checked and rechecked all of the components, continuities, capacitance, resistance; retested and juggled the tubes (six '01A's), and in desperation I switched power supplies and speakers. All to no avail.
Here's a couple of schematics which I used. The one labeled "Model 35 Only" is my modification of the Rider/Beitman schematics to show the Model 35 with only one filament rheostat. The Gernsback schematic is original, showing two rheostats.
https://flic.kr/p/2iqQCja
In addition, Leigh Bassett's modern drawing is at http://www.atwaterkent.info/TechData...wingIndex.html
So, experienced people, do you have any advice for me?
Thanks,
Henry
Winky Dink
Damn the patina,
Full speed ahead!
Old 02-08-2020, 08:47 PM
Gregb Gregb is offline
Double check the C- voltage on the output tube.
Gregb
Old 02-08-2020, 11:12 PM
Winky Dink's Avatar
Output tube C- Voltage
This is not a double check, but a first check. Here's the ARBE III setup:
Results (I hope one of these is the right way to measure grid bias):
From grid of the output tube to F- (A-/C+) +20V.
From grid of the output tube to F+ (A+/B-) +27V.
From grid of the output tube to chassis ground +24V
Thanks, Greg.
Winky Dink
Damn the patina,
Full speed ahead!
Old 02-09-2020, 12:06 AM
Possibly the 22v and -4.5 v supply connections are swapped?
Old 02-09-2020, 01:15 AM
Winky Dink's Avatar
Couldn't have swapped connections inside the ARBE, and the battery cable is not connected to C-22V or B+22V. Of course, I may have reversed the meter leads. With the battery cable totally disconnected from the ARBE, the C+ voltages (with the positive meter lead on C+) are C-4.5 -20v, C-9 -21v, and C-22 -34v. The A and B voltages are OK. Could I have done something to the power supply after the radio performed so well on its first test? I dunno. I changed power supplies, and it still didn't work.
Winky Dink
Damn the patina,
Full speed ahead!
Old 02-09-2020, 01:43 AM
Are the C voltages on the second supply also way out of specification?
I guess that I would try 3 flashlight batteries in series for the C supply and see how the radio works.
Old 02-09-2020, 02:45 AM
Winky Dink's Avatar
Good idea on the flashlight batteries. I'll try that, but first I'm going to check out my two K-101A battery eliminators along with Models 20 and 30 which are basically the same as the 35. If I can get a for-sure good power supply, then I try the 35 again. Thanks.
Winky Dink
Damn the patina,
Full speed ahead!
Old 02-09-2020, 04:24 PM
Winky Dink's Avatar
It's Fixed
Thank you Gregb, thank you jr tech.
This morning I set up the radio with a K101A Battery Eliminator adjusted for appropriate voltages. The radio worked normally. Not very good, but normal. Then I went back to the ARBE III supplemented with three D-cells for the C- voltage. It worked well.
Not an elegant solution, but it worked and it's only temporary. Now I can finish the project.
- Henry
Winky Dink
Damn the patina,
Full speed ahead!
Old 02-09-2020, 11:36 PM
Good to hear you got it going again.
Gregb
Old 02-10-2020, 02:35 PM
It might be interesting to measure the current that the radio draws from the C supply.... it should be very close to zero. If it is high, that might explain the power supply failure(s).
