Old 02-04-2020, 01:05 AM
The way caps are interlace wound they would have both film layers(plates) very close to the same AC potential. In essence both foil layers come to the outside, only separated by the thickness of the dialectic. What am I missing?
Old 02-04-2020, 07:00 AM
for the first time in over 40 years ( guess ) heaters be heating!
https://imgur.com/aaQgLaA
Bias is disabled, just a transformer / heater test.
Old 02-04-2020, 09:38 AM
thanx for the info, that is what I was looking for!
the stuff came today btw!
Happy to help.
Old 02-04-2020, 06:10 PM
i'm very tempted to try to build this https://imgur.com/VJr5U7Y
i have almost everything.
Old 02-05-2020, 09:43 AM
Adding an amp stage is another valid option.
Old 02-05-2020, 10:37 AM
I have thought of that, but it would be VERY hard on this, as everything after v14 ( audio desc/ det) is wired up very differently, and no schematic can be found for it.
https://imgur.com/oFR1Zab
hard to see in that, but if you look close, you can see a metal plate over the place where the socket for audio out v16 should be, audio amp v15 is there under that plate, but I have no clue how it's wired up w/o volume control.
There is a long audio cable coming out of where audio output v16 would have been that ran to the radio/amp.
At this point I'm thinking it's easier just to build an ext amp than to figure out how they modded it.
Old 02-05-2020, 11:02 AM
Rewiring everything after the detector isn't the worst...I have a certain fondness for phonos that contain RCAs 45RPM only mini changer the RP-168/190. One of my units was a 1 tube wonder that required a high output cartridge more expensive than the phono as a whole...So to adapt it to the $1 eBay crosley knock off carts I favor in these I converted the amp to the 3 tube version found in other models....I pretty much had to recreate it from scratch and do some engineering changes to deal with series heater differences. The result was quite decent.
I can be lazy sometimes...I know there's the Texas vintage radio and phonograph society in your state...If they are not too far away I'd probably just go to a swap meet and pick up the most appealing/affordable table set with a phono input and use that.
That said what everyou are comfortable with should be fine. This set has the most value to you so you are the only one that needs to be happy with it.
Old 02-08-2020, 02:25 AM
amp project started!
https://imgur.com/CAU6K24
https://imgur.com/ICo4KZq
Old 02-08-2020, 02:28 PM
Mutha Puss-bucket....
I expected the DC voltage to be a bit high with no load, but 480v?
It's hooked up to the 300 Vac center tap point on the power x-former, and I was not expect it to go that high when converted to DC. :/
I'm gonna have to stick some kind of voltage divider resistors on there to get it down :/
Old 02-09-2020, 10:39 AM
IT'S ALIVE!! IT'S ALIVE! HAHAHAHAHA!
https://www.youtube.com/watch?v=xos2MnVxe-c
https://imgur.com/8dudmlg
https://imgur.com/lM2ROjM
running off a variac as I don't have the resistors for the voltage divider yet.
https://www.youtube.com/watch?v=SM5g...ature=youtu.be
YES, the pot on my signwave generator is VERY dirty
but it's working!
Old 02-10-2020, 10:36 AM
A music playing test sort of worked, :/
but did not play very loudly, no surprise, as in order to keep B+ bias down, I have the input voltage quite low, and so the heaters are hardly getting 5 volts and so the 12AX7 is hardly lit.
I'm guessing it will get better once I get the resistors for the voltage divider and get things a bit more stable.
Using a modded version of this, https://tinyurl.com/stn9984
Will just have to play with it to get the voltage correct.
One thing noticed, the 6V6GT gets DAMN HOT :O, which, from what I have looked up is apparently normal for it.
All in all, once complete, and all the tweaking is done, this thing should fit in nicely in the Jensen speaker compartment in what ever is the final enclosure of this TV.
Old 02-10-2020, 10:48 AM
You could probably harvest the heater voltage off the TV chassis for testing....odds are it has the same transformer as the models with an audio amp, and even if it doesn't there should still be some headroom for it.
Old 02-12-2020, 12:04 PM
Sigh...
Trying to use that old 1955 era Sansui power transformer is giving me too much trouble, unstable voltage & weird AC leakages where there should be none, ( I have shocked the crap out of myself many times now cause of that. ), perhaps there was something wrong with them in the first place, and that's why they were donated to my class. :/
Trying another approach, I have an old beat up Sansui 1000 that used to work that I won't ever get to rebuilding, not worth it, it was in bad shape to start with, but I know the x-former in it is good, so I'm gonna pull that and use it, slightly adjusting the circuit that was in there, as it seem quite close to what I need.
I still may have to adjust for load, but I'm sure the weird ac leak problem will be gone with it, and I won't get 300+ ac shocks anymore! :p
https://imgur.com/7loNTco
orig Sansui 1000
https://imgur.com/8CTU69K
planned v2 power supply
edit/ add on
https://imgur.com/pteUqEl
Yeah, I should have looked more closely, I would have noticed there was something odd with these...
input power 0-85-100-110 0 – 5v3A
up top,
filament windings
0- 2.5 -2.5 -6.3 - 6.3 3A
0- 6.3 – 8.5 -15A 0- 6.3 – 8.5 -15A
hv sec out ( what I overlooked )
350 – 300 – 0 – 300- 350 but says DC130MA...
meaning, this SHOULD have built in rectification, if I am understanding this right, but it must be damaged, cause its putting out ac, and the winding leaks to the case when hooked up .
Old 02-12-2020, 12:42 PM
Sigh...
orig Sansui 1000
edit/ add on
up top,
filament windings
No built in rectification, just rated in DC because they knew it would get rectified in any normal application of the day.
Sometimes old transformers randomly develop leakage between windings....I used to use a 50's isolation transformer for working on not chassis radios 'safely'....one day the primary and secondary developed STRONG leakage on me while I was using it. I discovered that the hard way, then retired it...
Old 02-12-2020, 12:53 PM
Can you see the octal tube socket hole right next to the tuner? That was punched for an optional 6K6 audio output amp. You'd need to add an audio output transformer and volume pot, but man this would be so simple to add the amp stage right on your TV chassis. There may even be an extra control mounting hole on the front of your chassis? Fada made a model 925 TV only chassis that I'm pretty sure used the same basic chassis layout as your 895, which is why the hole for the optional audio output is there next to the tuner. I can post the schematic section from the 925 and you can wire it accordingly, that is if you're up for the challenge?
https://i.imgur.com/oFR1Zab.jpg
